Librem 14 running PureOS randomly freezes
My librem 14 freezes up after a few minutes of use on a fresh PureOS install. I am forced power off the laptop to get it to work again but it always reoccurs.
I am also unable to run memtest from the pureboot menu
Thats the error I get when trying to boot the memtest
Whats going on here, any ideas?
Two ideas:
  1. Reseat the RAM.
  2. Reinstall PureOS.
I would confirm what version of Pureboot you have. Is it the latest?
I would confirm what version of the EC firmware you have. Is it the latest?
Otherwise @jonathon.hall ?
Does your Librem 14 still freeze when you use a PureOS Live USB?
I’ve got a brand new Librem 14, and over maybe 2-3 hours of total use so far, it has frozen 3 times.
The machine was cool to the touch, so it’s not overheating or anything.
First 2 times happened on the machine in the state it was delivered in.
Last time was after replacing the RAM and SSD with upgraded components, installing PureOS onto that drive and installing all software updates.
I’ve also double checked versions of Pureboot and EC and everything is on the latest version.
Thanks to FLOSS FOSS philosophy of Gaming with Users and producing Poor Quality Software and Hardware the results are these. I have a Librem 14 and i know what going on and i know what i saying too…IMHO.
I recommend you contact Purism Support.
[moderator edit: updated link]
I had assumed that email was dead, as I’ve not received any responses to any questions/issues (mostly regarding L5) all year. That’s the only reason I’m on the forums..
I did find this old thread which seems to suggest it’s a known issue that is fixed in Crimson:
But, seems insane that such a critical issue has not been fixed with a backport or something years after the hardware was released.
Worst thing is that I lose work everytime it freezes. I’m guessing the FS writes are buffered and it fails to flush to disk when the system freezes.
OK, managed to email directly the person involved with the order originally. Apparently there’s a rare defect where the factory forgot to cover something, trying to figure out now if it’s the same issue. So, probably not the xwayland issue mentioned in that other thread.
Try downgrading to firmware 29. I had the same problem and downgrade solved it.
So, after finally getting in touch with support, they took the laptop back, confirmed the freezes and sent me a new one from the latest batch. The new one freezes even more frequently than the old one. After several months (with support failing to come up with anything) I finally figured out the freezes are GPU hangs and have found 2 workarounds to resolve them for now.
The first is a less frequent freeze (maybe happening once a week). You can tell if you have this freeze as the last thing in /var/log/syslog will say a GPU hang occurred and mention rcs0. To fix this one create /etc/systemd/system/fix-gpu-hang.service:
[Unit]
Description=Fix GPU hang
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'echo 10000 | tee /sys/class/drm/card0/engine/rcs0/preempt_timeout_ms'
[Install]
WantedBy=multi-user.target
And run sudo systemctl enable fix-gpu-hang.
The other freeze which happens far more frequently and doesn’t leave anything in syslog can be fixed by adding intel_idle.max_cstate=1 into GRUB_CMDLINE_LINUX_DEFAULT in the /etc/default/grub file. Then run sudo update-grub.
