Hi all,
I’ve run into a problem with the USB-C port on the right side of the Librem 14.
I understand that this is the one that should accept power delivery and provide display out. Neither of those functions have worked since day 1 of having this machine, but while it served as a USB port, I wasn’t too concerned. Now, however, it doesn’t recognise any devices connected to it.
(I’ve treated this laptop like royalty, so there’s no physical damage)
I’ve updated using the EC tool (v.2.5_2021-10-28) and have updated Pureboot to v20 using a stock image. No change.
Is there some script available that I might be able to run to determine the nature of a hardware fault? I’d prefer to try to diagnose/repair here rather than ship the machine back to Purism.
Any thoughts would be much appreciated before I open a support ticket.
Thanks in advance!
For info:
Output of ‘lsusb’
Bus 002 Device 002: ID 05e3:0749 Genesys Logic, Inc. SD Card Reader and Writer
Bus 001 Device 003: ID 0489:e076 Foxconn / Hon Hai
Bus 001 Device 005: ID 0bda:5830 Realtek Semiconductor Corp. USB2.0 camera
Output of ‘lspci’
00:00.0 Host bridge: Intel Corporation Device 9b51
00:02.0 VGA compatible controller: Intel Corporation Device 9bca (rev 04)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsytem
00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH-LP Shared SRAM
00:15.0 Serial bus controller [0c80]: Intel Corporation Serial IO I2C Host Controller
00:1c.0 PCI bridge: Intel Corporation Device 02be (rev f0)
00:1c.7 PCI bridge: Intel Corporation Device 02bf (rev f0)
00:1d.0 PCI bridge: Intel Corporation Device 02b4 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/eSPI Controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH-LP cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake SPI (flash) Controller
01:00.0 Network controller: Qualcomm Atheros AR9462 Wireless Network Adapter (rev 01)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Non-Volatile memory controller: Sandisk Corp Device 5019 (rev 01)
I don’t know if something is missing from these outputs because I don’t have a fully-functional L14 here to compare it with. As I said, any suggestions would be great!
