I am running Linux Mint 22.3 on a Librem 14. Since successfully installing the OS, I have had no problems with any of the hardware functionality. I recently had to turn off the WiFi/Bluetooth switch. When I restored the switch to the ON position, the wlan is no longer available and the Librem 14 is no longer visible to other Bluetooth devices.
The LED associated with the WiFi switch illuminates with the switch in the ON position.
Other than replacing a defection switch or WiFi adapter, is there anything else I can try to fix the problem?
I have recycled the laptop off and on a number of times to no effect.
Live Boot PureOS (or any other potentially relevant distro e.g. Ubuntu) in order to fault isolate your particular software and settings environment.
