I need help. while on battery, the laptop goes into suspend mode every minute, even while i’m working. I can not search for a setting in this time. So i need to know where to go specifically between suspends.
Thanks.
Thanks.
Settings --> Power --> Automatic Suspend
You can choose whether to suspend or not, and if yes, choose the delay for both battery power and plugged in
Thank you for your reply. I had those settings already. I had to plug in the laptop, then restart. The problem has not returned.
