Hey all!
I am getting ready to order a Librem 15, but I wanted to make sure it’s compatible with these specific items.
Could someone help me confirm?
16 GB RAM - Crucial:
https://www.amazon.com/Crucial-PC4-19200-Unbuffered-SODIMM-260-Pin/dp/B019FRBHZ0/ (dual-ranked?)
or
https://www.amazon.com/Ballistix-Single-PC4-19200-SODIMM-260-Pin/dp/B01DGOF0EC/ (not dual-ranked?)
I’m not sure which one’s better, actually.
2 TB SSD - Samsung - https://www.amazon.com/dp/B078DPCY3T
2 TB HDD - Seagate - https://www.amazon.com/Seagate-BarraCuda-2-5-Inch-Internal-ST1000LM048/dp/B01LWPEVPL/
(If I understand correctly, you can only fit in one 2.5 inch storage drive at a time. I may be opting for the HDD or the SSD depending on my budget).
Thank you very much!
P.S.
Has Purism published the part-by-part schematics for the Librem laptops? It’d be really helpful to have an exploded view or list, where you could check to see: “oh, this part has x width, y length, and z height,” or “it only takes this type of connection.”
