The Librem 15 has three switches, two on the right side and one on the left. The website that says it has two kill switches, one for microphone and camera, and the other for wireless and bluetooth. What is the third one for?
Hi Moonlock,
The third switch (the one on the left side) is a bios flash switch. Not sure what exactly is it for. I’ll reply back when I get more info.
Cheers
Oops… I’ve been messing with that switch ![]()
Yes please ! ![]()
I’m sorry, I forgot to reply here. This is a BIOS flash switch. You cannot update BIOS if the switch is off.
Brilliant ! am even happier with my Librem laptop now
Thanks Pejakovic !
cheers, HS
Is there a corresponding feature for the Librem 13? Perhaps inside the case? Or is the Librem 13 always flashable?
Which direction is off?
