Librem 15 v3 Boot into BusyBox built-in shell (initramfs)
I received L 15 v3 last week and I installed PureOS through USB. Every once in a while it boot into BusyBox built-in shell (initramfs)
I tried this already dozens of times -> https://askubuntu.com/questions/153852/can-not-boot-initramfs-error#214042
Edit: I also used gparted CHECK function several times.
after that it boot normally for 2-3 times and again goes into busybox.
Can anyone please help?
We had a similar situation, customer simply reinstalled his system and everything went back to normal.
Hello @mladen unfortunately I done that 3 times already and I followed this tracker
https://tracker.pureos.net/w/installation_guide/live_system_installation/
Could you check your coreboot version, please? You can do this via dmidecode command.
Also, what is your setup, do you have two or just one disk?
@mladen I dont know how to use dmidecode command but I looked into coreboot tables in boot menu and I found this:
4.6-500-gdd47******-4.6-a86d1b-purism-5 (seems like that is the latest one)
I have only one SSD installed that is Samsung 850 Evo.
Edit: dmidecode -t bios
dmidecode 3.1
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: coreboot
Version: 4.6-a86d1b-Purism-5
Release Date: //2017
ROM Size: 16 MB
Characteristics:
PCI is supported
PC Card (PCMCIA) is supported
BIOS is upgradeable
Selectable boot is supported
ACPI is supported
Targeted content distribution is supported
BIOS Revision: 4.0
Firmware Revision: 0.0
I re-installed PureOS and used sudo apt-get upgrade
in log I found this related to initramfs
Processing triggers for initramfs-tools (0.130) …
update-initramfs: Generating /boot/initrd.img-4.12.0-1-amd64
WARNING: Setting CRYPTSETUP in /etc/initramfs-tools/initramfs.conf is deprecated and will stop working in the future. Use /etc/cryptsetup-initramfs/conf-hook instead.
W: Possible missing firmware /lib/firmware/i915/bxt_dmc_ver1_07.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_dmc_ver1_26.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_dmc_ver1_01.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_ver9_14.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_ver8_7.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_guc_ver6_1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_huc_ver02_00_1810.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_huc_ver01_07_1398.bin for module i915
W: Possible missing firmware /lib/firmware/i915/skl_huc_ver01_07_1398.bin for module i915
I: The initramfs will attempt to resume from /dev/sda2
I: (UUID=ef*****---b**-c**)
I: Set the RESUME variable to override this.
Is this normal?
Yes, it is warning about possibly missing firmware and in reality those firmware are indeed missing as they are proprietary and not included in PureOS archive.
Might be a disk issue, I’m really not sure. Could you check the GNOME Disks application, if everything is okay with your disk?
disk is OK I checked with gnome disks and gparted as well
@zlatan-todoric thanks for the info.
hi there,
i had the same issue just thist year already. New PureOS-8.0-install and after apt-get upgrade booted into initramfs.
i’m afraid to upgrade again, because i need my laptop configured. BUT i also need the system up to date, as things don’t work so fine and because of security…
The last lines of the upgrade state:
Trigger für initramfs-tools (0.132pureos1) werden verarbeitet …
update-initramfs: Generating /boot/initrd.img-4.17.0-3-amd64
cryptsetup: WARNING: Resume target luks-4a798b7a-9b76-4203-9fa9-243a41cc1a0c
uses a key file
WARNING: Unknown X keysym “dead_belowmacron”
Trigger für libc-bin (2.28-5) werden verarbeitet …
Trigger für dbus (1.12.12-1) werden verarbeitet …
Trigger für libgdk-pixbuf2.0-0:amd64 (2.38.0+dfsg-7) werden verarbeitet …
Trigger für rygel (0.36.2-3) werden verarbeitet …
my crypttab looks like this:
GNU nano 3.2 /etc/crypttab
# /etc/crypttab: mappings for encrypted partitions.
# Each mapped device will be created in /dev/mapper, so your /etc/fstab
# should use the /dev/mapper/<name> paths for encrypted devices.
# See crypttab(5) for the supported syntax.
# NOTE: Do not list your root (/) partition here, it must be set up
#       beforehand by the initramfs (/etc/mkinitcpio.conf). The same applies
#       to encrypted swap, which should be set up with mkinitcpio-openswap
#       for resume support.
# <name>               <device>                         <password> <options>
luks-502bb2f1-33ca-418f-a287-73017e0981b9 UUID=502bb2f1-33ca-418f-a287-73017e0981b9     none luks
luks-4a798b7a-9b76-4203-9fa9-243a41cc1a0c /dev/disk/by-id/wwn-0x5001b448b60b6387-part3  /dev/urandom swap,cipher=$
Dmidecod output is:
root@purebox:/home/nikoz# dmidecode
# dmidecode 3.2
SMBIOS 2.7 present.
8 structures occupying 412 bytes.
Table at 0x7AA9D020.
BIOS Information
	Vendor: coreboot
	Version: 4.7-Purism-4
	Release Date: 03/20/2018
	ROM Size: 16 MB
	Characteristics:
		PCI is supported
		BIOS is upgradeable
		ACPI is supported
	BIOS Revision: 4.0
Handle 0x0001, DMI type 1, 27 bytes
System Information
	Manufacturer: Purism
	Product Name: Librem 15 v3
	Version: 3.0
	Serial Number: 304987
	UUID: Not Settable
	Wake-up Type: Reserved
	SKU Number: Not Specified
	Family: Librem 15
Handle 0x0002, DMI type 2, 8 bytes
Base Board Information
	Version: 3.0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
	Type: Laptop
	Lock: Not Present
	Version: Not Specified
	Serial Number: Not Specified
	Asset Tag: Not Specified
	Boot-up State: Safe
	Power Supply State: Safe
	Thermal State: Safe
	Security Status: None
	OEM Information: 0x00000000
	Height: Unspecified
	Number Of Power Cords: Unspecified
	Contained Elements: 0
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
	Socket Designation: Not Specified
	Type: Central Processor
	Family: Pentium Pro
	Manufacturer: GenuineIntel
	ID: E3 06 04 00 FF FB EB BF
	Signature: Type 0, Family 6, Model 78, Stepping 3
	Flags:
		FPU (Floating-point unit on-chip)
		VME (Virtual mode extension)
		DE (Debugging extension)
		PSE (Page size extension)
		TSC (Time stamp counter)
		MSR (Model specific registers)
		PAE (Physical address extension)
		MCE (Machine check exception)
		CX8 (CMPXCHG8 instruction supported)
		APIC (On-chip APIC hardware supported)
		SEP (Fast system call)
		MTRR (Memory type range registers)
		PGE (Page global enable)
		MCA (Machine check architecture)
		CMOV (Conditional move instruction supported)
		PAT (Page attribute table)
		PSE-36 (36-bit page size extension)
		CLFSH (CLFLUSH instruction supported)
		DS (Debug store)
		ACPI (ACPI supported)
		MMX (MMX technology supported)
		FXSR (FXSAVE and FXSTOR instructions supported)
		SSE (Streaming SIMD extensions)
		SSE2 (Streaming SIMD extensions 2)
		SS (Self-snoop)
		HTT (Multi-threading)
		TM (Thermal monitor supported)
		PBE (Pending break enabled)
	Version: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
	Voltage: Unknown
	External Clock: Unknown
	Max Speed: Unknown
	Current Speed: Unknown
	Status: Unpopulated
	Upgrade: Other
	L1 Cache Handle: Not Provided
	L2 Cache Handle: Not Provided
	L3 Cache Handle: Not Provided
	Part Number: Not Specified
	Core Count: 16
	Characteristics: None
Handle 0x0005, DMI type 17, 40 bytes
Memory Device
	Array Handle: 0x0000
	Error Information Handle: Not Provided
	Total Width: 64 bits
	Data Width: 64 bits
	Form Factor: Unknown
	Set: None
	Locator: Channel-0-DIMM-0
	Bank Locator: BANK 0
	Type: <OUT OF SPEC>
	Type Detail: Synchronous
	Speed: Unknown
	Manufacturer: Unknown (0)
	Serial Number: None
	Part Number: F4-2133C15-16GRS
	Rank: Unknown
	Configured Memory Speed: Unknown
	Minimum Voltage: Unknown
	Maximum Voltage: Unknown
	Configured Voltage: Unknown
Handle 0x0006, DMI type 32, 11 bytes
System Boot Information
	Status: No errors detected
Handle 0x0007, DMI type 127, 4 bytes
End Of Table
And i’m afraid of rebooting now!!
I do not want to re-install and re-configure permanently! i really need to work…
As this issue - for me - is still not solved,
what can i do??
OK SOLVED !!! :grinning::heart_eyes::smiley::+1:
This time i used:
sudo apt update && sudo apt full-upgrade
and I finally dared to reboot AND IT WORKED ! I’m so glad to have a working system after all that…
