I have a new Librem 15 v4, I was having a look at the setup having used coreboot before.
When running cbmem I get the results below which are very different to the expected output listed on the website https://puri.sm/coreboot/ can anyone advise ? I am assuming that it would be different as the v4 is not mentioned on this page.
./cbmem -c | grep ^ME
ME: Host Firmware Status Register 1 : 0xFFFFFFFF
ME: Host Firmware Status Register 2 : 0xFFFFFFFF
ME: Host Firmware Status Register 3 : 0xFFFFFFFF
ME: Host Firmware Status Register 4 : 0xFFFFFFFF
ME: Host Firmware Status Register 5 : 0xFFFFFFFF
ME: Host Firmware Status Register 6 : 0xFFFFFFFF
ME: FW Partition Table : BAD
ME: Bringup Loader Failure : YES
ME: Firmware Init Complete : YES
ME: Manufacturing Mode : YES
ME: Boot Options Present : YES
ME: Update In Progress : YES
ME: D3 Support : YES
ME: D0i3 Support : YES
ME: Low Power State Enabled : YES
ME: CPU Replaced : YES
ME: CPU Replacement Valid : YES
ME: Current Working State : Unknown (15)
ME: Current Operation State : M0 without UMA but with error
ME: Current Operation Mode : M0 without UMA
ME: Error Code : Preboot
ME: Progress Phase :
ME: Power Management Event : CM0PG->CM0
ME: Progress Phase State : Unknown phase: 0x0f state: 0xff
ME: Power Down Mitigation : YES
ME: PD Mitigation State : Issue Detected but not Recovered
ME: Encryption Key Override : Workaround Applied
ME: Encryption Key Check : FAIL
ME: PCH Configuration Info : Changed
ME: Firmware SKU : Unknown (0x7)
ME: FPF status : fused
