I’ve noticed higher temperatures than usual recently and I’m not sure which upgrade caused it. Last time I had higher temperatures, upgrading the kernel seemed to fix it.
uname -r
5.10.0-8-amd64
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +45.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +44.0°C (high = +100.0°C, crit = +100.0°C)
pch_skylake-virtual-0
Adapter: Virtual device
temp1: +42.5°C
I know it isn’t at dangerous levels, but it used to idle at least 7 degrees lower than that, and the fan kicks in far more often which gets a little annoying. Anyone else noticed this issue?
