Issue: Librem 5 Emulation Failure with Gnome Boxes
Log:
Broker URL: qemu+unix:///session Domain: boxes-unknown UUID: 2fbca83e-4b99-4297-842e-2251349ae3fd Persistent: yes Cpu time: 0 Memory: 2614848 KiB Max memory: 3733508 KiB CPUs: 4 State: GVIR_DOMAIN_STATE_SHUTOFF Domain config: ------------------------------------------------------------ <domain type="qemu"> <name>boxes-unknown</name> <uuid>2fbca83e-4b99-4297-842e-2251349ae3fd</uuid> <title>qemu-x86_64</title> <metadata> <boxes:gnome-boxes xmlns:boxes="https://wiki.gnome.org/Apps/Boxes"> <os-state>installed</os-state> <media>/home/usr/gnu-mobile/librem5/qemu-x86_64.qcow2</media> </boxes:gnome-boxes> </metadata> <memory unit="KiB">2614848</memory> <currentMemory unit="KiB">2614848</currentMemory> <vcpu placement="static">4</vcpu> <os> <type arch="x86_64" machine="pc-q35-4.1">hvm</type> <boot dev="hd"/> </os> <features> <acpi/> <apic/> </features> <cpu mode="host-passthrough" check="none"> <topology sockets="1" cores="2" threads="2"/> </cpu> <clock offset="utc"> <timer name="rtc" tickpolicy="catchup"/> <timer name="pit" tickpolicy="delay"/> <timer name="hpet" present="no"/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>destroy</on_crash> <pm> <suspend-to-mem enabled="no"/> <suspend-to-disk enabled="no"/> </pm> <devices> <emulator>/app/bin/qemu-system-x86_64</emulator> <disk type="file" device="disk"> <driver name="qemu" type="qcow2" cache="writeback"/> <source file="/home/usr/.var/app/org.gnome.Boxes/data/gnome-boxes/images/boxes-unknown"/> <target dev="sda" bus="sata"/> <address type="drive" controller="0" bus="0" target="0" unit="0"/> </disk> <disk type="file" device="cdrom"> <driver name="qemu" type="raw"/> <target dev="hdc" bus="sata"/> <readonly/> <address type="drive" controller="0" bus="0" target="0" unit="2"/> </disk> <controller type="usb" index="0" model="ich9-ehci1"> <address type="pci" domain="0x0000" bus="0x00" slot="0x1d" function="0x7"/> </controller> <controller type="usb" index="0" model="ich9-uhci1"> <master startport="0"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x1d" function="0x0" multifunction="on"/> </controller> <controller type="usb" index="0" model="ich9-uhci2"> <master startport="2"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x1d" function="0x1"/> </controller> <controller type="usb" index="0" model="ich9-uhci3"> <master startport="4"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x1d" function="0x2"/> </controller> <controller type="sata" index="0"> <address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/> </controller> <controller type="pci" index="0" model="pcie-root"/> <controller type="pci" index="1" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="1" port="0x10"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/> </controller> <controller type="pci" index="2" model="pcie-to-pci-bridge"> <model name="pcie-pci-bridge"/> <address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/> </controller> <controller type="pci" index="3" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="3" port="0x11"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/> </controller> <controller type="pci" index="4" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="4" port="0x12"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/> </controller> <controller type="pci" index="5" model="pcie-root-port"> <model name="pcie-root-port"/> <target chassis="5" port="0x13"/> <address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/> </controller> <controller type="virtio-serial" index="0"> <address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/> </controller> <interface type="user"> <mac address="52:54:00:f2:b1:4e"/> <model type="rtl8139"/> <address type="pci" domain="0x0000" bus="0x02" slot="0x01" function="0x0"/> </interface> <serial type="pty"> <target type="isa-serial" port="0"> <model name="isa-serial"/> </target> </serial> <console type="pty"> <target type="serial" port="0"/> </console> <channel type="spicevmc"> <target type="virtio" name="com.redhat.spice.0"/> <address type="virtio-serial" controller="0" bus="0" port="1"/> </channel> <channel type="spiceport"> <source channel="org.spice-space.webdav.0"/> <target type="virtio" name="org.spice-space.webdav.0"/> <address type="virtio-serial" controller="0" bus="0" port="2"/> </channel> <input type="mouse" bus="ps2"/> <input type="keyboard" bus="ps2"/> <graphics type="spice"> <listen type="none"/> <image compression="off"/> <gl enable="no"/> </graphics> <sound model="ich6"> <address type="pci" domain="0x0000" bus="0x02" slot="0x02" function="0x0"/> </sound> <video> <model type="qxl" ram="65536" vram="65536" vgamem="16384" heads="1" primary="yes"> <acceleration accel3d="no"/> </model> <address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/> </video> <redirdev bus="usb" type="spicevmc"> <address type="usb" bus="0" port="1"/> </redirdev> <redirdev bus="usb" type="spicevmc"> <address type="usb" bus="0" port="2"/> </redirdev> <redirdev bus="usb" type="spicevmc"> <address type="usb" bus="0" port="3"/> </redirdev> <redirdev bus="usb" type="spicevmc"> <address type="usb" bus="0" port="4"/> </redirdev> <memballoon model="virtio"> <address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/> </memballoon> </devices> </domain> ------------------------------------------------------------
Image Used:
wget https://arm01.puri.sm/job/Images/job/Image%20Build/lastSuccessfulBuild/artifact/qemu-x86_64.qcow2
