Librem 5 M.2 Question
If I put an M.2 nVME chip into the Librem 5 in place of the modem, would it be likely to function or would it break?
If it wouldn’t function, what obstacles should I expect?
Thanks guys!
(apologies if this is a duplicate, mods feel free to combine it if so)
I don’t think anything would break, but the NVMe device just won’t work in the phone as there’s no PCIe exposed in any of the M.2 sockets.
Obstacles that you won’t be able to solve.
FWIW, I’ve generally found M.2 NVMe cards in the smaller form factor (i.e. that would physically fit in the Librem 5) to be more expensive than M.2 NVMe cards in the more common 2280 form factor (which will simply not fit in the Librem 5). So even if it did work, it would be an expensive way of adding storage.
Sure but I have one of those small cards already I’ve not been using, could maybe put it to use.
Thanks! Appreciate the explanation, I was curious if I would’ve been stupid to try it.
Do we think the same will be true of the Librem 5 v2?
