On many times forcing by angles in plug ang unplug, it loose or broke the port.
You mean the PCB (instead the port)? And if this can indeed happen with the Librem 5 USB Type C port where:
The L5 is a professional phone. The aluminum extra protect the port, I mean mostly to loose or broke between the port and p.c.b when too much forcing.
@carlosgonz @Quarnero @dcz
I hardly used the phone.
It was pretty much dormant for the whole of January
I only received it in December
It never happened to me with any other phone I had before.
I have phones from 12 years ago that are in great condition.
If you already tested your Librem 5 like this (with removed battery):
youâll understand why you need to contact support@puri.sm, as recommended. But please leave broken USB-C port âstoriesâ aside even if my proposal here sounds stupid.
I have L5 evergreens and everything good on charging together system updates. But we has to know that L5 still is in under heavy development so we need to use original cable and charger for better performance. I think you need to do a physical inspection and see if you notice anything loose or bad.
Uhm, youâre taking my quote out of context. What I meant in that message is that you can configure the battery charger chip to cut the battery from the power path, so it stays unused while the phone is powered solely from USB; to do so you of course need to have your phone already running and operable.
I donât think thereâs anything to add in this topic that havenât already been said. If the phone doesnât react to USB input with battery taken out in any way after trying several chargers and cables (including USB-A to C cable), then itâs reasonable to assume that the unit is broken.
This is more than fair enough recommendation (to at least eliminate original charger/cable failure).
One experience Iâve had, with batteries in general, is that if a battery is drained too low, and/or left drained for too long, they sometimes are just dead and cannot be re-charged.
From what you describe, it sounds to me that, the battery was left depleted completely for an extended period of time and in turn this may be the root problem.
When a battery is deeply uncharged it often can be charged again by charging it longer. Maybe a charge over night might be worth a try.
My personal experience is that it is not âoftenâ charging for a long time will revive a battery in this state but closer to ârarelyâ.
I concede that my experience may not be as vast as others, and different battery compositions will have differing success rates, but I stand by my post that this is something worth considering; especially for future readers looking for troubleshooting steps.
Iâve had pocket lint build up in a USB-C port, couldnât plug it in all the way and the phone wouldnât charge. The solution was to extract the lint using a plastic toothpick.
Similar thing happened with my Android and its headphone jack. I bought some headphones and was only hearing one channel. I thought the headphones were defective, but eventually figured it out.
I agree, this is important indeed, but donât think that this taking easy approach helps here (turning on Librem 5). Anyway, in his post #6 within this thread @Skalman already pointed out (somehow) that empty battery leads to the second problem: âstarting the phone after the battery is dead enough for the RTC to resetâ, see his post here: Why is there no Wifi? - #14 by Skalman.
This RTC reset issue is certainly possible as there even exist recent laptops (that include PCI IDs: 15bf, 15d9, 15d2 and 15eba) where they were able to boot into any OS, even show that the battery health status is almost 100% but its charging status was showing 0% even after several days of charging. Therefore looks like âitâs best not to let your battery go under 20%â while if the RTC lasting time completely runs out, the system will lose this information and the real-time clock/calendar wonât be able to recover, something that @sherab_kelsang didnât take into account (as there exists no official warning, so let me finally relax). Actually, I have no clue what is going on, but I donât think that we have any issue with the battery manufacturer (or USB-C port). IMHO, things here are complex and might even âinvolve SPI flash chip to store the firmwareâ.
Thatâs exactly why the recommendation is to plug USB in without a battery connected, because this way you can quickly determine whether itâs the battery or the device.
BTW - I wouldnât say it sound stupid (the idea that the port is broken) as of course these things can happen.
But I suppose for it to break means excessive or incorrect usage.
I am a very conventional normal user - taking care of my devices.
Yes, you are having right, perhaps I could have wrote âstupid ideaâ (on possibility, rather just my thought in wrong direction, that âthe phone operates solely on USB powerâ) or nothing or think of some other description rather than stupid (although I didnât want to be unpolite, not purposely or consciously). Therefore allow me to to express my sincere apologies to @carlosgonz, related (to be precise) to broken USB-C port âstoriesâ!
All we wanted, participants in this thread, was to find appropriate advice for your situation, to tell you please check this and that. Anyway, @sherab_kelsang thanks for being kind to me! I just wasnât thinking of that I might be harsh to someone as Iâm stupid enough (donât know everything, at least not right away, even if/when I need to be clever, perhaps). And this another idea wasnât out of focus (someoneâs own) here, not at all. And, I just didnât expect that you hear what I said (wrote about someoneâs else opinion), yet hearing another person is something important for everyone (thanks again!). On the other side I didnât want to read every post that was sent to you (next time Iâll try not to) and I shouldnât follow broken USB-C flow, but I did, sorry. Let me try, no ⌠I just wish to myself to be as calm as you are, I guess.
You are ok, stay calm, we all make mistakes.
And following the issue of the L5 charging problem, and thanks to Purism for creating a libre and repairable device, the repair of the L5 is easy, I consider that your @sherab_kelsang L5 is not dead yet ⌠inspect it and see if you can repair it, or follow the instructions of the Purism support.
Hey man - youâre great!!
And I always listen.
From listening we find wisdom.
From listening we liberate our self from great ignorance.
Yeah - I am not that worried - one way or another it will be fine. It is already fine. We cannot let trivial things be in our way to great successesâŚ
