Librem 5 Phone startup
Hi This is not a major issue as the phone still works. However.
The first time I tap the phone app all I get is a blue screen.
Then I swipe up and tap the Phone app again and phone works ok.
Just wondering if this is an issue that has a solution,
Thanks
Have you tried sudo apt reinstall gnome-calls?
I’ve noticed the same thing. I open the calls app, it doesn’t load up. I open it up again and it works just fine.
After an update the issue is resolved.
