Librem 5 problem punchlist
Not a bad idea. I don’t necessarily want to bombard people with thread update notices, but at the same time interested people might miss the updates if I’m just editing post #1 dozens of times.
I guess you’ll have to choose one or both, then. :wink:
For info, though, editing the OP doesn’t bring it to the “latest” list of topics. Only new entries in the comments do that.
  • PureOS Store hangs when searching for apps or browing categories with endless spin indicator. SOLVED
It can be done with some terminal and UI haggling. Not ready for prime-time though.
Open to feedback about superior methods
Got as far as getting Gnome Authenticator installed but still working on extracting the OKTA QR code embedded ‘secret’ which Authenticator refers to as the ‘2FA token’.
After further haggling it doesn’t look like Gnome Authenticator can be setup with OKTA secrets unless the OKTA admin dashboard specifically enables third party OTP apps.
Successful workaround was getting OKTA verify installed using Aurora store on Waydroid, then configuring with setup link texted to voip.ms messaging app.
Just got external dock connected logitech mouse wheel scrolling enabled for Librem 5.
just published script and XDG shortcut to toggle dark theme off and on for Crimson users.
I got Handy working with double-press of volume down button trigger on Librem 5 w/Crimson.
Thank you @galilley for the Handy backporting work.
New HOWTO dropped for patched millipixels app
