Ah right.
Because no one else ever posts anything off topic
No, flagging because wildly off-topic hijack. Not flagged by me.
If you want to talk about other things, start a new topic and in an appropriate category.
I see your point. Although, I guess I’m just not as sensitive to it. For instance, right now, you and I are having a conversation about ‘forum decorum.’ Isn’t this off topic, technically? Shouldn’t we be flagged?
Btw, I honestly don’t mind the community flagging system. It’s a pretty good system which solves a number of problems. Yet, I know full well, people are not very judicious creatures. Passion is what rules the day usually.
See what I mean? There’s too much personality in the flaggings. It’s not objective. Rather, it betrays some obvious bias. Namely, talking about the virus, of late.
Since the off-topic is getting out of control in this thread, mine is the last one, and then posts will get axed. thank you for cooperation.
I think you can update this line after the last news: Coronavirus Update – Purism
- confirmed “dimmable” (with source)
- added source for proximity (upstreamed, yay!)
@Caliga shouldn’t we have calendar in the apps as well?
Besides, about IP native calls, if intended via Matrix that does not work yet (not sure about xmpp). Fractal does not support voice calls nor does purple-matrix which is used by Chatty.
Thanks for providing such a nice overview.
It should be LPDDR4 since Dev Kit
@Caliga battery 3600 mah no ? or is that subject to change again for evergreen ?
Hm. This page says 3500 mAh:
https://puri.sm/products/librem-5/
But this article talks about 3600 mAh:
https://www.phoronix.com/scan.php?page=news_item&px=Librem-5-Dogwood-Thermal-Power
But it’s also fun to see, that batch fir is not listed at all
Updated a few shipping dates, battery size (@reC, @Skalman), RAM (@Freedom_Right).
@henry-nicolas, a calender app was not promised as part of the original campaign. (And, to my knowledge not yet demonstrated / worked on by a Purism employee). However, it’s part of the Fund-Your-App initiative, so I’m pretty sure we’ll have something in the not to distant future
@wednesday, Fir is a future product, possibly Librem 5 v2, and the only thing promised about it is that it will be a thing eventually. Doesn’t make much sense to add it here. After Evergreen has been shipped to all backers (that did not switch to Fir) I consider the campaign and its promises done.
This post needs a review
You need help for that?
For this part, you can connect a debugger via the wifi/bt slot
About that I would show this: Librem 5 Laptop Mode – Purism
These are just two examples. But I did not wanted to edit the wiki myself, as I might be a little bit (just a little bit) biased ![]()
Sure! Always open for suggestions. Improved debugging and convergence.
Is there a better source for HW debugging options than your statement?
What would qualify as “Privacy protection by default”, is it different from “does not track you” ?
Edit: also added Geary, mail client
Gnome calendar UI is not in any way optimized for mobile but it does work perfectly fine. Depends how high the expectations are for it to qualify as delivered I guess .
Laptop mode is not the same as desktop mode. A better link: A Librem 5 Video Made on a Librem 5 – Purism
