P.S. Probably best to update/upgrade prior to reflashing if the plan is to copy some previous elements over to the new install.
Refer: Tips & Tricks · Wiki · Librem5 / docs / Librem 5 Community Wiki · GitLab
When I reflashed recently, Geary made it too difficult to save and restore the config file around the reflash. So instead I opted to save the config files before the reflash, set the accounts up again from scratch and then use diff to make sure that I got it right or to correct any minor failure to set it up exactly as it was.
If using Firefox then I think the correct approach with bookmarks is: export, reflash, import. However I didn’t have Firefox installed (was only using Epiphany) so that didn’t apply to me.
