Librem 5 PureOS unused "Desktop"
Does anyone know of plans or sources for the ‘desktop’ on the Librem 5?
At the moment it’s all in the App Tray(?) with search and I can’t find a way of adding shortcuts/widgets (future stretch goal) to the ‘desktop’ itself for quicker access to commonly used apps as you would normally do on a desktop OS
Gnome is not meant to use Desktop icons, you press the overview button and you will see the common apps and you can also type to search any other.
It would be nice a Dock like the Ubuntu touch one, that you pull from the left hand side of the screen, but I don’t if we will be able to install extensions in Posh.
I’ll be switching to KDE ASAP, gnome is not my flavor of choice.
