Librem-5 v2 a RISC-V Phone
Software support is my main concern, now. Recompiling the PureOS repo packages is one thing. But what about Flatpaks and Flathub? I don’t see any movement on supporting RISC-V.
Mobile Linux wouldn’t be where it is today without Purism plowing a path. I’ve heard people in the mobile linux space who aren’t into Purism still echo this sentiment. I don’t think there is debate that the Librem 5 campaign made the difference.
I just hope we can say the same for Linux RISC-V support in a few years. Flathub (for example) would never support RISC-V if people aren’t using it in the first place.
Here is what the announcement says at the moment.
ARM64 compatibility
We must be able to execute ARM64 code efficiently to support Flathub and Android apps. ARM64 emulation for RISC-V exists, but needs optimization.
You mean that brown and gold screen in your first screenshot? It’s probably just a mockup, but I’m sure you could create something very similar yourself.
Edit: @carlosgonz Actually there is a similar wallpaper in Appearance in the L5 settings. In the file system, it’s located here: /usr/share/backgrounds/gnome
@irvinewade , could we have a separate category or tag in this Discourse instance specifically for Librem 5 v2 to collect all the posts about it and distibguish them from the original Librem 5?
Probably having a single category for both is fine.
Hardware > Librem 5
But having a single tag for both is not enough.
librem-5
Edit: The new tag is now available: librem-5-v2
Yes the brown-and-gold image. The image loook very interesting… it ship many features.
I do not think i may create a clone to looks same on my L5.
Thanks i will check.
I can not create new tag. @janvlug can do it.
No, als also cannot.
Are you sure you can’t? If you click on the pencil icon next to your title, and then click in “Optional Tags,” it doesn’t let you add e.g. “librem-5 v2” and then save it?
(post deleted by author)
New tag it can not save it, the box is just to search a existing tag.
I guess @Pirate_Praveen blocked this option.
That worked. How you did?
Me, too: Tag created for Librem 5 v2 topics
:rofl:
