Librem coreboot Utility Script: usage, discussion, and help
@MrChromebox I just got my new Librem 14. The first thing I wanted to do was to update coreboot. I used the script without any problems but after that I got coreboot version 4.16-8-gf88975265a (04/25/2022) - so I started the script again and got the message ** Update Available: 4.16-Purism-1 **.
I rerun the script with the same result a few times. My question is: Am I doing something wrong or is this expected behavior?
Coreboot 4.17 is not available yet on Purism repos build release, when 4.17 is available it need download the Script again to update coreboot to 4.17 so that is why the old script is showing the old coreboot 4.16.
My posting is not about coreboot 4.17. I use the script to update coreboot to the current version (whatever that is). When I start it it says Update Available: 4.16-Purism-1 - so OK, I want to use it to update coreboot to version 4.16-Purism-1.
But it fails to install 4.16-Purism-1, instead it installs 4.16-8-gf88975265a. So when I start the script again, it tells me Update Available: 4.16-Purism-1 again. I can rerun the script several times - afterwards it will always tell me that an update is available.
Where do you see this version? in coreinfo?
Try download the script again, because the script work offline version checker.
It normal behaviour of the script, but confusing. It same happen with me here too.
I can see it when I start the script, there’s the line
Version: 4.16-8-gf88975265a (04/25/2022)
I can also see it when I use
dmidecode -s bios-version
I already did that. I happens with the current script version.
Yeah i think it is bug, because on 4.15 it showed the right version but on 4.16 the thing was different, it happened to me too so i hope that @MrChromebox fix this on coreboot 4.17.
did you update via the precompiled image, or building from source? Sounds like the latter and the 4.16-Purism-1 tag didn’t get pulled correctly, so it used the next available one (4.16).
no, it’s not
No, I updated via the precompiled image (several times with the same result).
looking at the precompiled image, not sure why the tag is missing. But looking at https://source.puri.sm/firmware/coreboot/-/tags you can see that 4.16-Purism-1 and the commit with hash f8897526 are the same, so you are indeed running the correct/latest version
OK, thanks!
found the issue, there was a variable name change in the build script for the 4.16 release, and it was missed in one spot, leading to the version string being set as empty.
Nice. Give me v4.17 corrected. :slight_smile:
you can build it yourself from our repo if you wish (using the librem_4.17 branch), but there’s no 4.17-based release yet
Thanks but i like the release build. I want and waiting for coreboot v4.17 + Librem EC v1.8 + Librem Control on my L14.
A post was split to a new topic: Librem Control app discussion
I have a librem13v2. I’m using arch linux with sway as my main system, and a live usb of the latest stable debian to run the coreboot update.
I hadn’t updated coreboot in a while.
I tried creating an account on source.puri.sm to open an issue, but
Your account is pending approval from your GitLab administrator and hence blocked. Please contact your GitLab administrator if you think this is an error.
I have noticed some new bugs since I updated (I used the precompiled option) :
  • When I push fn+:speaker_medium_volume: and fn+:speaker_high_volume:, I need to push the :speaker_medium_volume: and :speaker_high_volume: twice instead of once (arch and debian).
  • fn+F9 changed from XF86HomePage to XF86WWW (not a bug per say), but now when I push ctrl+fn+XF86WWW or maj+fn+XF86WWW or ctrl+maj+fn+XF86WWW, it is all recognized as fn+XF86WWW instead.
  • The grub menu doesn’t take all the screen anymore. It maybe halved in size.
  • I noticed the laptop being warm, which doesn’t usually happen.
I then tried the locale compilation option and it failed, but then I saw Script fails to compile coreboot, cannot find python (#9) Ā· Issues Ā· firmware / utility Ā· GitLab, ran
sudo apt install python-is-python3
and after that it worked.
(time to reboot :smile:)
You should email support@puri.sm to get your account approved.
Is this script run in dom0 or any VM will do ?
I downloaded the script, ran it in a qube VM on debian 11 and fedora 34, and it did nothing.
It turned out the dmidecode package was missing.
Since this is the boot soffware being updated, I’d like to do this the secure way.
Thanks
Uzma
Unless your VMs have full access to the BIOS, you have to run it in dom0. Or you can boot into LiveUSB version of PureOS and do it from there.
The first link of the first post says
Project ā€˜coreboot/utility’ was moved to ā€˜firmware/utility’. Please update any links and bookmarks that may still have the old path.
