I’m seeing this on the doc manage passwords, provide multi-factor authentication
but I’d like to understand how can I use librem key for totp 2fa and what means password manager and how can be used?
Install nitrokey-app
app.
Installed it but I can’t use it.
Throw: Device not initialized
Should I install other dependencies?
I’m not using PureOS but Qubes OS if that may be a problem
Is your Librem Key connected to the same VM where you installed the app? Did you try to do everything in sys-usb?
I connected to the same vm
I tried also on Ubuntu [not a VM, separate laptop] and I’m having same problem
What is your version of the package libnitrokey
? If it is lower than: 3.6
then it will not work
Was able to make it working with 3.7
And how can I use the app with librem key for e.g. github?
