qxotk
March 13, 2021, 10:03pm
1
When I purchased my LMv2 I chose not to acquire a Bluetooth adapter.
I am finding that I would like to have it.
I tried searching for “Ar3k” was not able to find anything.
Does anyone know what hardware spec I would need to search for or where I can purchase the same adapter that Purism is using?
fralb5
March 13, 2021, 10:39pm
2
Maybe try to contact support@puri.sm about it
I think they should expand their shop site with more of this kind of things
You can find another Bluetooth adapter supporting free driver and free firmware here:
https://tehnoetic.com/tet-bt4 .
tracy
March 14, 2021, 1:05pm
4
There are bluetooth adapters that look like a USB stick. This presumes you have a free USB port and you don’t mind where it comes from (probably China).
qxotk
March 20, 2021, 12:50pm
6
Thanks to all for the replies and suggestions.
I am more interested in something internally attached - more like what Purism provides when ordering the Librem Mini from them directly.
I believe the suggestion I will follow is to contact them directly via their support email address.
If I hear back I will update my post.
