Librem tunnel onto librem 15
went through the worksheet process using tilix up until the command pipx install ldh-client after which it declares not installing to existing directory … pass ‘–force’ to force installation ?
just checking if anyone has carried out this and did it operate with advised process on librem one helpsheet or what did you do
Hi @aljf33
I went through these instructions on my Librem Mini, which will be the same as the Librem 15.
https://docs.puri.sm/Librem_One/PureOS/VPN_Tunnel.html
These instructions worked for me.
Hi thx for reply , that’s exactly the instructions I followed and all went well until it stalled at the command I highlighted above
Can you paste the full command + error message you are seeing?
Thank you for reply I shall do that next time I try it
