Hello, everyone.
Can someone explain to me what exactly i must do with those two files? Which directory am i supposed to put them into, and where can i find those directory?
Thanks
Hello, everyone.
Thanks
In the two lines of red text, everything up to the last / is a directory. After that is the file name. So you navigate to the same directories on your computer and put the files there so the file paths match.
Open the terminal application Tilix and run the two following comands:
wget https://docs.puri.sm/_downloads/6d38dd063966ab4052abd58cd617b1e4/85-libremkey.rules
wget https://docs.puri.sm/_downloads/10ed9b281420d0842cc85240943f74e9/gnome-screensaver-lock
This will download to your home folder the two files you need.
After that, run the following commands from the same terminal window;
sudo cp 85-libremkey.rules /etc/udev/rules.d/85-libremkey.rules
sudo cp gnome-screensaver-lock /usr/local/bin/gnome-screensaver-lock
This will copy the two files to the correct directories (folders).
After that is done you can either run the following command:
systemctl restart udev
or just reboot your computer.
Also, you had already made the same question on another thread, I would kindly ask you not to double post. it’s just easier to follow a specific topic and a question if it is all in the same thread.
Pinged the wrong person in this thread, sorry
Hello, and thank you for your answer. I’ve dowloaded the file, but when i try to copy them, i’m asked to enter my password, ans then nothing happen. It’s like the command is ignored. Do I need root privilege to copy thoses files? if so, how can I get it?
edit: i tried sudo -i, gaining root privilege, and i entered the fist copy file command. The answer was than no such file or directory exist…
is there a way to find those folder in the gnome environment and simply drag them? I looked everywhere, i think i must be blind.
If the command above does not work - which would be very strange - you can open Nautilus, type CTRL + L and navigate to the paths by typing admin:///etc/udev/rules.d
If it appears that nothing happened then that means it worked. You can double check by typing “ls /etc/udev/rules.d/” and seeing if the file you just copied is in the output. The ls (lowercase L) command lists all the files and directories in a given location.
Also “sudo” is a one-off command that executes the command after it with root privileges.
