I saw an article about how to have my computer lock itself (gnone) when the Librem key is removed. Has anyone here been able to accomplish this?
If someone who’s done this could post some easy to understand steps for the less savvy members like me, you’d be a real hero. I’ve wanted to get this set up for a while and haven’t had much success.
The explanations are not very clear to me. What I’m I supposed to do with those two files?
I would guess
- download each file
- put each file in its respective directory (as given at the top of the article)
- restart (either the service using the command shown in the article, although I would guess it needs
sudo
in front of the command, or the whole computer)
i’m sorry but which directory are you refering to ?
@kieran already gave the correct answer. However, if you are just getting started with Linux then check out the following links:
- https://linuxhandbook.com/linux-directory-structure/
- https://www.togaware.com/linux/survivor/ - in particular, look at the “Basic Administration” section, especially the “File system”.
In Terminal:
sudo nano /etc/udev/rules.d/85-libremkey.rules
Paste this:
ACTION=="remove", ENV{PRODUCT}=="316d/4c4b/101" RUN+="/usr/local/bin/gnome-screensaver-lock"
Type: CTRL X Y
sudo nano /usr/local/bin/gnome-screensaver-lock
Paste Content of the screensaver-lock file (see link above)
Type: CTRL X Y
systemctl restart udev
This feature does not work for me with the two mentioned files, but I got it working by changing the udev rule to
ACTION=="remove", KERNELS=="0003:20A0:4108*", SUBSYSTEMS=="hid", RUN+="/usr/local/bin/gnome-screensaver-lock"
after having fiddled with udev man page and udevadm
commands (mostly monitor
and info -a
). I hope the KERNELS prefix value I use in this rule is not specific to my particular device; it looks like the second number is the vendor ID, and the third the product ID. I ordered my Librem key in February 2019.
