I have this Librem 5 problem where sometimes if I am traveling with all the hardware switches off so the machine is a totally offline handset in its own universe, and I want it to stay that way, I have found that I can put it in my pocket and later pull it out, and the outward friction of the pants pocket pulling it out of there hooks onto the HKS physically and toggles it, disabling lockdown mode and enabling the networking because the friction button movement is indistinguishable to the hardware from a human action with intention to toggle the switch.
I think this happened twice for me today and with different switches. It makes me feel as if I cheated myself, or a little down, because I spend all this effort to be a Librem 5 user but then have my idea for security, peace of mind, and honestly reduced EMF exposure to my internal organs, all totally thwarted by a pair of pants.
Librem 5’s get used by paranoid people. And maybe in another thread someone could discuss the merits or lack thereof of being paranoid. But if we assume a human is paranoid, and then assume they are using HKS, but have their HKS thwarted by pants, this seems like a very negative and demoralizing user experience, because with paranoia you can believe that maybe the US government picked to manipulate you into using those pants, or any number of ludicrous paranoid ideas. And that’s probably not the case, you know, this is probably simply an accident in the manufacture and function of the Purism hardware.
But I wondered, does anyone else experience this problem and do they find a way to restore peace of mind and avoid it?
put a small piece of painter’s tape over the switches
No idea if that will work or if that will quickly be rubbed off as well, but it’s an idea! I have also seen threads about 3D printed cases that might help too.
Purism improved the HKS from Dogwood+ however moving HKS to HKB could be better to prevent turning 0n. However with current engineered HKS even with law of the nature this can not be turned 0n unless you are provoking it.
I have had the opposite happen, where I have them all on, but later discover they have been switched off. Presumably from having travelled to or from my pocket. It’s usually the top one, Network, that gets moved.
It hasn’t been frequent enough or specifically problematic for me, though.
You can try those Faraday bags mentioned here last year. So it should be offline even if you switch flips, Although I also noticed you may accidentally flip one of those switches when pulling your phone out of the bag.
Another choice would be a rubber drop protector, it should also make the switches hard to get at.
Sometimes switches or buttons are affected by other types of actions, such as moving/sitting in slim jeans. Accidental dials do occur even with other smartphones.
