Does anyone know if it is safe for L3 circuit to run a 10 meter (about 33 feet) from L13 to TV ? Or I need to buy some kind of extender (over eth or wireless) ?
most standard (passive) HDMI cables are good for about 5m, so for 10m you’d definitely need either a repeater or to use something that supports longer distances, like HDMI over Ethernet (eg)
Oh, OK. So 5 meters is OK and safe for Librem13. Thank you!
I haven’t tested one myself, I’m just relaying what the spec says you should be good with
