Major Issues after "OS Update" on Librem 5
Nothing’s unusual then, except of you using sudo apt upgrade when you should use sudo apt full-upgrade.
No, nothing’s out of ordinary there. The message is about physical keyboards in the console.
No need to bother unless you want to use other on-screen keyboards than Squeekboard.
That was the solution. Thanks :+1:
I’m just now seeing this thread. I have not turned on my L5 for almost two weeks now, was going to start it up before I saw this thread, so therefore my L5 has not encountered this upgrade (and the resulting problems) yet.
Am I understanding the current situation correctly: At this point if I turn on my L5 and run the offered updates as usual I should avoid the problems discussed in this thread?
And, is the recommendation that I run any updates via apt in the command line, or use the Pure Store - or does it not matter?
I am always ssh connecting to my Librem 5 from my Debian laptop and using apt (apt-get) to update (upgrade).
2 days ago I upgraded my Librem 5 without any problems.
I recently updated today using sudo apt update && sudo apt upgrade -y just fine, but I do happen to have flashed a very recent Evergreen LUKS and DAS U-Boot image.
