Make XDG shortcuts for AppImages easily using Create Launcher
There is a handy utility called Create Launcher which allows users to easily create XDG compliant application launcher shortcuts for AppImages.
Previously I was doing this by editing .desktop files by hand which was error prone and tedious. Now I can do it in a couple of clicks with this excellent utility.
Steps to get started.
  • Clone the software git repo cd /usr/local/src; git clone https://gitlab.com/rastersoft/create-launchers
  • Install the Nautilus script as user (do not run as root) ./install.sh
  • Open Gnome Files app and right click on any AppImage file, then select Scripts => Create Launcher
  • Fill out the dialogue box as desired, at minimum, check the "Add to applications list” box under the “Destination:” section near the bottom. You might also have to select a category in the drop down menu before the “Save Launcher” button will become active.
It seems that a gitlab account is necessary.
Strange, that just started happening, I was able to clone without a password when I made the post.
Sorry, I found a typo in the original command (missing an ‘s’ at the end) This one should work
purism@pureos:/usr/local/src/create-launchers$ ./install.sh
ln: failed to create hard link '/home/purism/.local/share/nautilus/scripts/Create launcher' => '/home/purism/.local/bin/create_launcher.js': Invalid cross-device link
Not sure what the problem is.
Edit: Nevermind I had my bin on my sd card
