Many problems starting the Librem 5
Hi folks, please suggestion: I want buy microsd 2TB to use it now as backup storage for my PC and then, when I’ll receive my L5, as data storage.
Just I can’t find it!! It seems no one want produce 2TB microsd!!!
I saw sundisk, Samsung, Amazon… I found just one French brand that produce it, bought it on Amazon but was broken!! Impossible to format, impossible to set luks… so refunded!
Please someone can suggest me a trusted brand (quality!!) and where you buy it?
Thank you :pray:
@veleno
aren’t microsd ,in general, extremely fragile when it comes to data storage because how subsceptible they are to write/read errors??
Anyway, SanDisk is a reliable brand. Sandisk Extreme microSD A2 is a 1TB version. Just buy it twice and split your backup in 2 parts.
Most likely it was a counterfeit uSD card, particularly if the price was very good for a card of that size.
I would stick with 1 TB - but even that will be relatively expensive.
