Millipixels Won't Save Rear Camera Pics
Millipixels never saves pictures when taken on rear camera. Instead it only displays progress wheel either spinning or frozen. It will take videos and selfies. Any ideas?
Is this the regular Camera (Preview) default app, or an independently installed Millipixels package?
It’s the default app.
Mine still works perfectly. I suggest emailing support@puri.sm if you haven’t already. Or maybe @dos has some ideas.
You might try running the terminal command
millipixels
which will launch the camera app. Attempt to take a photo. Then post the terminal output here so people can take a look.
Thanks Amarok. The terminal output is shown below:
purism@pureos:~$ millipixels
Found config file at /usr/share/millipixels/config/purism,librem5r4.ini
Adding camera big from config
matched GRBG8 to GRBG8 3
Adding camera selfie from config
matched GBRG16 to GBRG16 14
Found postprocessor script at /usr/share/millipixels/movie.sh
Found postprocessor script at /usr/share/millipixels/postprocess.sh
mp_device_list_find_remove imx7-csi s5k3l6xx 3-002d
18: there’s csi, looking for s5k3l6xx 3-002d
18: there’s csi capture, looking for s5k3l6xx 3-002d
18: there’s imx8mq-mipi-csi2 30a70000.csi, looking for s5k3l6xx 3-002d
18: there’s hi846 2-0020, looking for s5k3l6xx 3-002d
17: there’s csi, looking for s5k3l6xx 3-002d
17: there’s csi capture, looking for s5k3l6xx 3-002d
17: there’s imx8mq-mipi-csi2 30b60000.csi, looking for s5k3l6xx 3-002d
17: there’s s5k3l6xx 3-002d, looking for s5k3l6xx 3-002d
found!
devname /dev/video1
found!
linking flags 0 source 15:0 sink 10:0
MPDevice: MEDIA_IOC_SETUP_LINK error 22, Invalid argument
mp_device_list_find_remove imx7-csi hi846 2-0020
18: there’s csi, looking for hi846 2-0020
18: there’s csi capture, looking for hi846 2-0020
18: there’s imx8mq-mipi-csi2 30a70000.csi, looking for hi846 2-0020
18: there’s hi846 2-0020, looking for hi846 2-0020
found!
devname /dev/video0
found!
linking flags 1 source 15:0 sink 10:0
Setting mode 1052 780
[0:37:22.805366147] [5447] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[0:37:22.823438947] [5451] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for ‘s5k3l6xx’
[0:37:22.823519950] [5451] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:37:22.824206615] [5451] WARN CameraSensor camera_sensor.cpp:476 ‘s5k3l6xx 3-002d’: Unsupported ancillary entity function 131074
[0:37:22.825436422] [5447] INFO Camera camera.cpp:1029 configuring streams: (0) 1052x780-SGRBG8
[0:37:22.826045085] [5451] ERROR DeviceEnumerator device_enumerator.cpp:166 Removing media device /dev/media1 while still in use
ok
Setting mode 4208 3120
[0:37:25.392911204] [5447] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[0:37:25.412869996] [5495] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for ‘s5k3l6xx’
[0:37:25.413144446] [5495] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:37:25.413849473] [5495] WARN CameraSensor camera_sensor.cpp:476 ‘s5k3l6xx 3-002d’: Unsupported ancillary entity function 131074
[0:37:25.415108080] [5447] INFO Camera camera.cpp:1029 configuring streams: (0) 4208x3120-SGRBG8
[0:37:25.415709543] [5495] ERROR DeviceEnumerator device_enumerator.cpp:166 Removing media device /dev/media1 while still in use
ok
talked with support about a month ago, they verified everything on my l5 was up to date but didn’t have anything concrete at that time… If I can get this resolved soon, I won’t have to tote around the old crapple iphone to take pics which would be awesome. Any ideas or suggestions are much appreciated!
