Good day all
Iis there software i can install in PureOS which will let me minimize applications like browsers and so on for the desktop.
I see Firefox dont have suck and option
Regards
Try clicking with the right mouse button on the title bar of a window (or alternatively - on the keyboard for the active window).
You should get a menu for the window with various options including an option to minimize the window.
the general look of the window titlebars can be changed with the gnome-tweaks app.
There you can add the at least in my option missing buttons for minimize and maximize to all windows
I did try it, its not there
Thanks
I will give it a try
Did you try calling the window menu by keyboard with holding the -key and then pressing the bar, also? For this to work your Firefox window needs to be active.
To minimize a window by keyboard you could also hold the -key and then press .
Thanks so much gnome-tweaks work
I do have one last problem if someone can maybe please assist
I installed Barrier, when I share my screens, my mouse pointer is not picking up on Pureos, but the keyboard is working
