MirrorLink compatibility?
Will the phone be compatible with MirrorLink ?
Hi,
thank you for the hint and pointer to this interesting technology.
Looking at the websites though it seems unlikely that we can support this technology. First of all device manufacturers are obliged to become members of the CCC consortium which likely incurs a substantial membership fee. Also applications development is currently only support for Android, if I understood the website information properly. Since we are not going to use Android on the Librem5 but PureOS, we will not be able to support MirrorLink directly. But of course as long as specifications would be open (which they are as to what I found not exactly) there could be an open source / free implementation of the protocols which could then again also be used on the Librem5.
So for short: No, most likely this will work or be supported, I am sorry.
Cheers
nicole
