Anyone get a phone without a bluetooth adaptor?
I live in South Africa and received the phone with no bluetooth. It was an evergreen. I mailed the company and got no reply either.
pureos
description: Computer
product: Purism Librem 5r4
width: 64 bits
capabilities: smp tagged_addr_disabled
*-core
description: Motherboard
physical id: 0
*-cpu:0
description: CPU
product: cpu
physical id: 0
bus info: cpu@0
capacity: 1500MHz
capabilities: fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid cpufreq
*-cache
description: L1 Cache
physical id: 0
*-cpu:1
description: CPU
product: cpu
physical id: 1
bus info: cpu@1
capacity: 1500MHz
*-cache
physical id: 0
*-cpu:2
description: CPU
product: cpu
physical id: 2
bus info: cpu@2
capacity: 1500MHz
*-cache
physical id: 0
*-cpu:3
description: CPU
product: cpu
physical id: 3
bus info: cpu@3
capacity: 1500MHz
*-cache
physical id: 0
*-cpu:4 DISABLED
description: CPU
product: idle-states
physical id: 4
bus info: cpu@4
*-cpu:5 DISABLED
description: CPU
product: l2-cache0
physical id: 5
bus info: cpu@5
*-memory
description: System memory
physical id: 6
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 6.3.0-1-librem5 xhci-hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 6.03
capabilities: usb-2.00
configuration: driver=hub slots=1 speed=480Mbit/s
*-usb
description: USB hub
product: USB 2.0 Hub
vendor: Microchip Technology, Inc. (formerly SMSC)
physical id: 1
bus info: usb@1:1
version: 9.02
configuration: driver=hub maxpower=2mA slots=3 speed=480Mbit/s
*-usb:0
description: Mass storage device
product: Ultra Fast Media Reader
vendor: Generic
physical id: 1
bus info: usb@1:1.1
version: 2.09
serial: 000008264001
capabilities: usb-2.00 scsi
configuration: driver=usb-storage maxpower=96mA speed=480Mbit/s
*-usb:1 DISABLED
description: interface
product: Qualcomm CDMA Technologies MSM
vendor: Qualcomm, Incorporated
physical id: 2
bus info: usb@1:1.2
logical name: wwan0
version: 0.00
capabilities: usb-2.00 logical
configuration: driver=qmi_wwan driverversion=6.3.0-1-librem5 firmware=WWAN/QMI device link=no maxpower=500mA multicast=yes point-to-point=yes speed=480Mbit/s
*-usbhost:1
physical id: 2
bus info: usb@2
logical name: usb2
version: 6.03
capabilities: usb-3.00
configuration: driver=hub slots=1 speed=5000Mbit/s
*-network:0
description: Ethernet interface
physical id: 3
logical name: usb0
serial: ee:f7:07:84:8c:0b
capabilities: ethernet physical
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=dwc3-gadget link=no multicast=yes
*-network:1
description: Wireless interface
physical id: 4
logical name: wlan0
serial: 88:da:1a:7d:2f:8c
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=RSI-SDIO WLAN driverversion=6.3.0-1-librem5 firmware=N/A ip=192.168.77.11 link=yes multicast=yes wireless=IEEE 802.11
It looks like it recognizes the wireless card, and bluetooth is on the same card.
Can you check the obvious stuff like hardware kill switch? As well as the software toggle in settings?
Can you open the terminal app and enter the command bluetoothctl
and then enter list
to show whether it recognizes the adapter
showâs no output from list.
purism@pureos:~$ bluetoothctl
Agent registered
[bluetooth]# list
And in GUI says no bluetooth found. All HW kill switches are âenabledâ. Wifi is connected for example.
Thanks for the help.
ASwyD2
August 6, 2023, 6:13pm
4
Silly question, butâŚ
Is the soft switch blue?
You mean in the GUI? attached.
ppisa
August 6, 2023, 11:06pm
6
It seems as the switch is in the OFF position. If you tap on the software switch and move it right it should change position and color to blue. Or does it move back to left and stay grey?
I canât slide it to the right. Whether I tap it or drag it, it does nothing. Itâs indicating it doesnât see any bluetooth and itâs not possible to toggle it on.
Okay, I have a few ideas:
Remove, than reattach the Wi-Fi/Bluebooth modem.
If that does not change anything, reflash a new Evergreen image.
amarok
August 8, 2023, 1:01am
10
Be aware that this is a delicate operation with a high propensity for breaking the antenna cables, @divansantana .
You should read some of the recent posts on that topic before attempting, as others have talked about how they accomplished it (with or) without breaking the cables.
But actually, I recommend emailing support@puri.sm first, and following their troubleshooting recommendations.
As has been pointed out, if you have working WiFi then this is impossible (as they are on the same card).
When did you receive your phone? It looks as if you have the previous make of WiFi card (which is OK) but it would be good to check that. Tips & Tricks ¡ Wiki ¡ Librem5 / Librem 5 Community Wiki ¡ GitLab
So rather than consider that you have no Bluetooth adapter, I would be looking at
card firmware version
card operating mode
Give Purism Support a bit more time to respond.
Photon
August 8, 2023, 5:05am
12
IMHO, thatâs the best advice given so far. The WiFi and BT are co-resident on the same card, right? âNo Bluetoothâ means exactly that. You canât HK disable them separately and this is the message if disabled by the soft button:
Given that, I bet that the BT part of the card is defective and Purusm will send out a new card! Any takers?
I would bet against that except that Iâm not a betting man.
I mailed them âTue Dec 21 15:19:33 2021â with no reply. So I donât think I need to give them more time to reply.
Iâll mail them again today.
I have reflashed recently and no difference. Let me contact them and report back.
thanks all
divansantana:
2021
LOL, OK, my bad. I assumed that because you created this topic 2 days ago it is a recent problem.
Regardless though some of the information that I have suggested you supply here would also be needed by Purism Support e.g. make of card (Iâm now assuming Redpine), firmware version of card, operating mode of card.
I would guess that reflashing the phone will not change the firmware version of the card.
Your guys input was correct.
Flashing doesnât update the firmware and the firmware on the wifi card needed to be updated.
I contacted purism support and they replied and told me how to update the firmware. They said they replied in the past. Though I donât have the reply.
Anyway, here is the simple instructions for the sake of completeness.
wget https://source.puri.sm/angus.ainslie/firmware-rs9116-nonfree/-/raw/debian/master/Firmware/RS9116_NLINK_WLAN_BT_IMAGE.rps
sudo mv RS9116_NLINK_WLAN_BT_IMAGE.rps /lib/firmware
reboot the phone.
You can later safely delete this firmware with this command:
sudo rm /lib/firmware/RS9116_NLINK_WLAN_BT_IMAGE.rps
Thanks amigos.
Photon
August 10, 2023, 4:27am
17
Yeah, me too!
Still think OP should buy a SparkLAN card and fix two things at once.
