return the error:
error: couldn’t connect the modem: 'GDBus.Error*org.freedesktop.libqmi.Error.Protocoal.CallFailed: QMI protocol error (14): ‘CallFailed’
ip address show wwan0
wwan0:(…)
link/none
In addition, where can I set addition APN settings?
Such as MMSC, Proxy MMS, Port MMS, MCC, MNC,
those are provided by the mobile compagny to configure internet (and MMS), but withing the system APN settings there is not much fields.
Your are trying to connect to the MMS APN of bouygtel.
MMS are not yet integrated in the librem 5
You can take a look here for the last news about it : State of MMS on Librem 5
Is the baseband switch ON ?
is the cellular icon visible in the top of the screen ?
Are you connected in 2G 3G 4G ?
Did you try to use the web browser ?
is the APN for bouygues telecom (in france). It is used for MMS AND to access internet as well.
Yes, all fine. And internet does not work with web browser.
(call and sms OK)
