I’ve had two times the case that the modem indicator in the top status line went away and also in system’s Settings there was no entry Mobile anymore. I found no other way than doing a power off reset to make calls possible again. A plain reboot, i.e. without power-cycle, made the modem appear again, but calls were not working.
What could be the reason?
For what to look in /var/log/syslog?
What could be done without reboot?
I’ve tested the script. It does reset the modem and the symbols about cell network and 4G appear again in the status bar, but the modem remains unusable for calls, the app is just hanging.
