My first Librem 5 application
Hello everyone,
One of hobbies is photography and I often shoot with large format field cameras. These require some calculations to be done depending on how you are using the camera. I also often shoot with filters and do some macro photography, requiring to do some exposure calculation.
I am not a great programmer, so it will be very plain basic C. Fill x-1 number of values, press calculate. As long as you keep the program open, the values will remain there, so you can suspend your phone, operate the camera, and then recall the values at a later time.
This is work in progress. When I have a basic version ready, I will upload it with source somewhere to benefit the whole community.
The development is being done directly on the Librem 5 connected via USB-C to a very dumb Gigabyte Aorus FO48U monitor.
edit: I am also trying to make it adaptive, so it looks decent when rotated or when using an external display.
In case it helps you or anyone else wanting to program for Librem 5, there was a series of blog posts about it, which have some pointers:
and
Good resources were also mentioned in https://forums.puri.sm/t/application-development-for-librem-5/
Thank you. I am aware of all these sources but it is a nice thing to see them all under the same post!
It is evolving slowly, but surely. I try to spend some 20-30 minutes on it every day.
I did some progress today.
This is still only the GUI, missing the code behind - I need to review the math for it.
Then I will add features to calculate exposure when using different kinds of filters.
It’s working very fine and I have tested it in the field.
I shot a 4x5 Fuji Provia slide in macro (requiring distance calculations) and I also shot a sheet of 8x10 ISO 25 film (requiring exposure calculations), and both photos turned perfect.
However, the application does not perform the same way as when I run it from GNOME Builder. In the Builder, it launches instantly (it is a tiny program) but, once I launch it from phosh, it takes multiple seconds to launch, because I think it is launching a bunch of libraries (as I am using Purism defaults for Builder, I think they are using older libraries).
Also one of the sliders is very hard to tap. When I hold the slider and drag, the application window moves a bit (like if it would be a few pixels wider than the horizontal resolution of the canvas), so I have to tap and tap and tap the slider until I get the value I want.
Before I can release this into the wild, there are some weird things going on…
I wrote a small function to convert shutter speeds, for example, if I enter 1/2, then it is naturally 0.5 seconds when it comes to calculating exposures. It works perfectly if I launch it from Builder, but if I install it, it doesn’t, telling me that I have entered an invalid value.
I ran out of ideas to what could be the problem but I will have time to seek help from development gurus only when I have a few days off.
Continuing on the “create a first app for a linux phone”, the earlier examples, and how to do the whole project, I found from Linmob.net’s links a new tutorial site: https://oormila94.codeberg.page/ It’s a guide that explains how to build a complete graphical application for mobile linux, including creating a Flatpak of it for distribution. Very straight forward. No prior experience needed (but obviously helps).
[Edit to add: Kudos belongs to Oormila Raveendran Andaythu]
I dislike Flatpaks (check my saga on upgrading to Crimson to see why) and I couldn’t figure out how to publish my application, so I use it for myself. =)
Unfortunately, I don’t get a lot of free time these days, but I assume that I am probably the only person in the world that both has large format photography as a hobby and daily drives a Librem 5.
My friends tell me that I like to suffer.
