Great that it’s stable now.
It seems as if this is an issue to watch.
I don’t really want to drag my whole (2.4 GHz wireless) network down. Fortunately most devices are on 5 GHz anyway. (I see that my 2.4 GHz radio is on 20 MHz width by default, with the other option being 40 MHz - while my 5 GHz radio is on 40 MHz width by default, with the other options being 20, 80 and 160 MHz.)
If you are in a congested environment - lots of neighbors using WiFi or you yourself have multiple WAPs - then there isn’t a lot of point using 40 MHz channels on the 2.4 GHz band. So you aren’t losing much by limiting your access point to using 20 MHz channels.
It is also possible that the WiFi card in the L5 is capable of using a 40 MHz channel on the 2.4 GHz band but the settings from the host aren’t right for that at the moment. Needs more investigation …
