I bought the 3-cell battery for my Librem 14, but it does not appear to charge. I was able to use it for a bit, and it shut down. Now when I plug in the power adapter, I get a green light and when i try to boot up, it blinks and immediately turns off (and the green light goes off until I unplug and plug the adapter back in).
Anyone know how to get this straightened out?
Thanks!
I would recommend contacting Purism support directly via support@puri.sm
You might need to update the EC firmware:
i tried that; had the dickens of a time getting the drive to boot but updated it. Unfortunately, it is still not working.
I will try that. Hopefully we’ll be able to figure something out.
