New Librem15 and APT Update Will Not Work
I attempted to run apt update and below is what I received on my Day 1 Librem 15. Any thoughts as to what exactly is/is not going on?
Thanks in advance.
Hit:1 https://repo.puri.sm/pureos green InRelease
(appstreamcli:2528): GLib-CRITICAL **: 18:25:59.600: g_variant_builder_end: assertion ‘!GVSB(builder)->uniform_item_types || GVSB(builder)->prev_item_type != NULL || g_variant_type_is_definite (GVSB(builder)->type)’ failed
(appstreamcli:2528): GLib-CRITICAL **: 18:25:59.600: g_variant_new_variant: assertion ‘value != NULL’ failed
(appstreamcli:2528): GLib-ERROR **: 18:25:59.600: g_variant_new_parsed: 11-13:invalid GVariant format string
Trace/breakpoint trap
Reading package lists… Done
E: Problem executing scripts APT::Update::Post-Invoke-Success ‘if /usr/bin/test -w /var/cache/app-info -a -e /usr/bin/appstreamcli; then appstreamcli refresh-cache > /dev/null; fi’
E: Sub-process returned an error code
Did you see this site when you googled the error?
https://www.suramya.com/blog/2018/08/fixing-the-appstreamcli-error-when-running-apt-get-update/
it looks pretty similar; without more information I don’t know what else to suggest.
I found similar errors here, and apparently just running
sudo apt full-upgrade
should suffice to resolve the errors.
You are the man! I really appreciate your help. I am ecstatic about the Librem.
The solution is suggested here: PureOS: apt update fails
