There is plenty of argumentation based on superficialities of communication regarding this. I’ve tried to look past the daily infos and arguments on what’s really going on. Some partial musings:
As things are, communication (including both, factual and the meta feelings connected to it) is not in a normal state between Purism and it’s active audience (supporters, customers etc. - there are separate external audiences too). Although it can be argued, that communication is never in a equilibrium, and crisis may be too strong of a word currently (as comparatively, the orverall situation has improved immensely, as has the communication effort, but also because there are bigger crises), this is not a neutral situation. A mistake would be to think and respond as it were. Hence, the expectations, methods and processes need to be adjusted accordingly.
So, tenets of crisis communication should be observed, or would most likely be appreciated by the audience. One of them is to communicate more, not less, which has been done, but apparently just not enough. Hence, I’d argue that there is room for improvement, as with most things, and it is not a sign of failure. This does not mean giving up for instance specific numbers. One area seems to be planning of communications, although it’s hard to plan when it’s so tied to the uncertainties of production - yet there is still plenty to do there (but that too would need resources, people, time - luxuries at this point, if I’ve assessed the situation even half right). One other thing is to understand that complete and timely, and fully internalized communication, is not possible - choose one of the first two, the third is not completely in anyone’s control (but can be helped).
Normalization of situation and normalization of communication go somewhat hand in hand. Meaning, to Purism “hang in there” and “work will get you out of your hole”. Meaning to us, the audience, hopefully some good communication practices become of this even for normal times. It also means, that over time (and it does indeed take time), people begin to understand and adjust expectations regarding communication and it’s message (intended, unintended, obvious and abstract). In good, this means people begin to be less ready to have tantrums and be more thoughtful, as every detail isn’t as shocking. Those who’ve been here a few years had their (me included) meltdown moments (here or elsewhere) some time ago. So, we’re not in sync, as it were. So, a cycle or a wave repeats, as new people join. Things are better now. For a time, it seemed things were going really bad, leading towards apathy, less engagement and disbelief.
Right now, it seems the similar arguments are repeated about every 3-5 months. Sometimes with some new ingredients, but the same base elements. And even with the nastier exchanges, the undercurrent is one of expectation and support. The community created within this audience hasn’t been given enough to work with to create anything much else to support, so only thing left is to react to the infos and provide feedback. It’s sometimes energy not so well spent, which is a shame, as there is all this energy just looking for an out. With enough resources, a community coordinator (again, a luxyry) or such, we’d had time to have an L5 coding academy or translate everything to all the languages or something like it (wiki and some info threads are also examples). The energy is there (which I see as being better than not having it, apathy), it just isn’t efficiently managed (and may not be possible to manage but a part of it).
There are enough events, twists and forks in communication from the past few years that I’d hope to see someone writing a paper or thesis about it - maybe a case report as part of academic studies or some such.
Sorry about the long ramblings only tangentially connected to the topic.
