As we outlined in a previous post, the Librem 14 is the first Purism laptop to ship with our new, free software Librem-EC firmware for the laptop’s embedded controller (EC). This was a big undertaking, and as with any effort of this magnitude, issues arise in corner cases that often don’t show themselves during developmental testing, when only a small number of devices are tested. One such issue was with the power sequencing — the order and timing of all the different voltage rails and power sources/signals in the laptop.
The Problem
We were preparing to ship out the first batch of Librem 14s right as we were putting the finishing touches on the firmware (both for the embedded controller, and the main coreboot/Pureboot firmware), and everything was looking good to finally get devices flashed and into our users’ hands. But as we flashed the laptops’ firmware to prep for shipping, a small but not insignificant number of devices were failing to boot. At first we thought the issue was with our flashing process, which was new for the Librem 14, as both the EC and main firmware are flashed in sequence on a live system. But re-flashing these problematic devices externally (using a USB flash programmer and a chip clip) did not resolve the issue, so the issue wasn’t with the flashing process itself.
Initial Troubleshooting
Since our flashing process didn’t appear to be the issue, the next step was to determine if the issue lie within the EC firmware or coreboot. As it is easier to get live debug output from the EC than coreboot, we started there. We compiled and flashed a debug build of the EC firmware, and attached the debugger. The debug console showed that the EC was booting and properly transitioning the main CPU from off (the S5 power state) to normal boot (the S0 power state). Since the laptop was in S0, it meant that coreboot should be running, so it was time to see what was going on there.
Read the rest of the post here:
