Chrisk
October 11, 2024, 11:07am
1
Hi there, I am new to LibreM5 and have only just started and activated pureOS.
I have already run into two problems, which I cannot find 1,2,3 in the FAQ either. So I would like to ask for your help with the following:
I made a mistake in providing the password for the WiFi and now I dont know how to change this password.
I have opened a number of apps, but have no idea how to close them??
Thanks a lot for your suggestions. Chrisk.
Chrisk
October 11, 2024, 11:22am
3
Yes that works, thank you
Chrisk
October 11, 2024, 11:24am
4
Now oth problems have been solved. I found a way to reset the wifi password in setting. Thanks for the help.
I’m not on wifi now, but IIRC you can open the wifi settings, and either select the wifi or there’ll be a settings wheel next to the wifi you can select. You should then be able to select and edit the password entry.
Chrisk
October 11, 2024, 11:27am
6
yes thank you. I have found it in the settings and was able to delete the wifi and set the password again now the correct one .
amarok
October 11, 2024, 2:36pm
7
Overview and usage: Librem 5 - Purism - Librem products documentation
Also see the Librem 5 Tour app, which should be installed already.
