So many choices… I have no idea what each is…
What is the most appropriate package to run on a new Librem 13 running PureOS?
I am a bit surprised to see that many different options. The bionic
and xenial
are targeting specific versions of Ubuntu.
On a Librem laptop, you will want amd64
, as that is the architecture used by current Intel CPUs (and AMD CPUs, but the Librems don’t ahve those).
You can also use the AppImage version - AppImage is an alternative to Flatpak and which acts kinda like the typical Windows .exe
experience
Thanks.
(For anyone else using this package, the one that worked was the amd64.deb bionic version.)
Or, to put that in another way:
There is also a clue in the end there: .deb is a debian package, which is what a lot of distros have build on and use (Ubuntu and it’s many flavors [Kubuntu, Xubuntu etc. that are almost the same but have modified some aspect of the distro], Mint, PureOs…). Others are rpm etc. The flatpacks, appimages and snaps are trying to build a system which would simplify this but the cost is efficiency as they add another layer in between - which may or may not be an issue.
