No Sound Recorder app found on the PureOS Store.
No Sound Recorder app found using apt in a terminal.
Where can I get Sound Recorder app?
Thank you!
Thank you!
Odd. Gnome Sound Recorder (sudo apt install gnome-sound-recorder) should be available. If not, you can get that as flatpak too, if you need something quick. Alternatives: https://flathub.org/en/apps/search?q=sound+recorder&main_categories=AudioVideo&arches=aarch64
Yes, IIRC, Sound Recorder is installed by default.
