@carlosgonz I’ve tried the kernel and found it improved things a bit. The reason for instability of WLAN is signal strength due to the log messages:
Feb 19 12:36:24 pureos wpa_supplicant[506]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-72 noise=9999 txrate=6000
Feb 19 12:36:24 pureos wpa_supplicant[506]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=9999 txrate=6000
Feb 19 12:36:30 pureos kernel: wlan0: disassociated from 3c:a6:2f:e7:c8:52 (Reason: 33=DISASSOC_QAP_NO_BANDWIDTH)
Feb 19 12:36:30 pureos systemd-networkd[368]: wlan0: Lost carrier
Feb 19 12:36:31 pureos kernel: redpine_91x: rsi_mac80211_set_key: RSI del key
Feb 19 12:36:31 pureos kernel: redpine_91x: rsi_hal_key_config: Cipher 0x0 key_type: 2 key_len: 0
Feb 19 12:36:31 pureos wpa_supplicant[506]: wlan0: CTRL-EVENT-DISCONNECTED bssid=3c:a6:2f:e7:c8:52 reason=33
But that’s is not really true. The L5 was placed very close to the router and other devices don’t share the problem. As said, the kernel improved things a bit. Thanks.
I’ve set up another router with better results. At least i get WiFi when not being absolutely close the router. Good enought for now.
To be more explicit about the situation when i received “No Wi-Fi Adaptor Found”: It was immediately after a reboot forced by holding the power button. Together with the problem above, i believe it could just have been a “hanging bit” of some kind. Contrary to jsjjnbrunk i had that particular situation only once.
@jsjjnbrunk I’d thus support the advice to try the charging step and make some probes with the router.
