Old Links to Store Still Fail
Yes, if you’re downloading software for the Librem 5.
That doesn’t work. I showed why.
I’ll go with the one that works.
I’m here today to find out how to remove the old PureOS Store icon and replace or create a desktop shortcut to new browser dependent one. I’m sure I’ll find a how-to as I seem to remember reading about creating desktop shortcuts.
I don’t like using a browser to get there - but it’s the only alternative there is.
~s
Launch Web, go to desired website.
Then Preferences “hamburger menu” dropdown > Install Site as Web Application:
Then Create; change the name if you want to:
Then it appears in your app grid (alphabetized):
To delete any web applications you’ve created:
Launch Web > Preferences “hamburger menu” dropdown > Open Application Manager > Delete button.
It’s a good idea to perform sudo apt update (and sudo apt upgrade if there are any waiting updates) before installing a new application. (It’s possible your website method will do that automatically, but I’m not sure.)
The only “Web” on this L5 is the browser called Web. In that Preferences > there is no “Open Application Manager”
Not my “method”. Ya can’t pin that one on me :rofl:
The browser method is one that works. Others have pointed out that the link on L5 desktop to PureOS Store does not work for them either.
I wonder why Puri is ignoring it doesn’t work right:thinking:
SideNote: (maybe you know who might believe me and pass it on.)
I was just browsing the working store and after about 30 minutes, noticed the icon for Pure OS Store (app?) is missing the icon on the working site.
~s
My bad… The actions I mentioned are in the “hamburger menu,” which also contains “Preferences.” But no need to go into Preferences. Sorry.
Fixed.
No clue. :man_shrugging:
Make sure you review my comment to you from a few days ago: Install From sotware.pureos.net - NOT! - #16 by amarok
I meant “your method” in the sense of “the website download way that you’ve been talking about.”
