Did you consider, also, those? ![]()
Community-driven, decentralized FLOSS search engines
You asked if there is a search engine created and managed by a community, decentralized, with no tracking/cookies, based on FLOSS philosophy.
Here are the closest options:
1. YaCy
- What it is: a true P2P decentralized search engine.
- Every user who installs YaCy becomes a “node” in the network and helps index the web.
- FLOSS: fully open source.
- Privacy: no centralized tracking, no personal logs—data stays on your computer.
- Pros: the most “pure” project in terms of decentralization and FLOSS ethics.
- Cons: result quality is lower than Google/Bing because the network is smaller and less powerful.
Official site: yacy.net
2. SearXNG (modern fork of Searx)
- What it is: a community‑driven metasearch engine: it doesn’t have its own index but queries other engines (Google, Bing, DuckDuckGo, etc.) and anonymizes all requests.
- FLOSS: yes, open source with many community‑run instances.
- Privacy: no tracking, no personal logs (depends on which instance you use—better to choose community‑trusted ones).
- Pros: very high‑quality results, since it pulls from multiple search engines without exposing you to tracking.
- Cons: not truly decentralized in terms of indexing (still depends on the “big guys”), but decentralized as a federated network of instances.
Find public instances here: searx.space
3. MetaGer
- What it is: a German independent search engine, non‑profit, open source.
- Not centralized like Google, but also not P2P like YaCy: run by a foundation.
- Privacy: no tracking, open code, servers in Germany (strict data protection laws).
- Pros: stable project, reliable, trusted for years.
- Cons: not fully decentralized.
In summary
- If you want the most decentralized, hardcore FLOSS solution → YaCy.
- If you want the best balance between privacy and search quality (but less decentralized) → SearXNG.
- If you prefer a stable, ethical, non‑profit project but not P2P → MetaGer.
Simple formula:
- YaCy = “grassroots engine”.
- SearXNG = “best compromise: privacy + results”.
- MetaGer = “ethical no‑profit centralization.”
