I am finding that adjusting the display to 175% suits me and fits everything on the screen. On reboot though it reverts back to 200%.
Is there any way to make 175% persistent?
Not that I am aware of.
Shame. 175 is perfect. Minor problem of course!
I think wlr-randr --scale 1.75 should change the scale (check man wlr-randr for documentation). Then it’s just a question of running that at startup, for instance with a systemd unit or a cron.
See old threads: Tutorial: Create Shortcuts to Scale Display Up/Down and Problem setting up desktop shortcut for a shell script - #7 by ASwyD2
Thank you! I thought it might be possible with something like this. I’ll investigate.
You can call the fix “175 proof” for marketing purposes. Need to be over a certain age however, but you can add the age of the modem.
The place to set this is
/usr/share/phosh/phoc.ini
Backup the original
cp /usr/share/phosh/phoc.ini /usr/share/phosh/phoc.ini.org
Edit the display settings (uncomment #[output:DSI-1])
sudo nano /usr/share/phosh/phoc.ini
[output:DSI-1]
scale = 1.75
restart phosh
sudo systemctl restart phosh
Thank you. That’s pretty straightforward actually.
False proof…I’m now 67. The beneficiary however of two cataract operations that gave me back teenage vision and got rid of my glasses that I’ve had for 30 years ![]()
Great, mark @laccata’s post as a solution.
Done. Excellent.
Good for you. ![]()
When I applied that solution, I ended up with a black screen after booting, so I had to reverse it.
Did you remove the # from #[output:DSI-1]? This line is commented out in the default file.
#[output:DSI-1]
#scale = 2
Updated
[output:DSI-1]
scale =1.75
If you leave it commented you will get a black screen - I did.
That’s the wrong way to do which can end up with huge issues (depending on your use case).
The correct steps are:
Creating the file /etc/phosh/phoc.ini including the may non existing directory. Put in:
[output:DSI-1]
scale = 1.75
Save. Everything is done. Instead of restarting Phosh (nothing wrong about it, but not necessary), the 175% scale can be chosen in settings app.
What’s wrong with your solution? An update can overwrite /usr/share/phosh/phoc.ini. I changed my Phosh UI too and I use 150% screen scale. The result was after an update that I could not enter PIN without physical keyboard attached, because the UI was scaled outside of screen space.
Thank you for these replies. I might just wait I think.
I held off, not wanting to battle the small keyboard.
You’re welcome. But as I said, /etc/phosh/phoc.ini is save. It overwrites the specific lines of the other file and is fully under your own control. Using it for many month now.
