Phone Case option?
After reviewing previous posts from 2020 - anyone find a solution for a Librem 5 phone that works for them? TIA
See here: Case for Librem 5?
I found a better solution meanwhile which I have not posted there yet.
Interesting, thank you. Is the better solution working better than what you have been using? Is the better solution reproducible or are you willing to share what it may be? :slightly_smiling_face:
Yes but I better make the pictures at daylight (have it on my todo list for a while).
Meanwhile I also learned that the newer revisions are longer (153 vs. 150mm) which also explains why the “full cover” case was too tight and the next one is very tight as well, but since it’s made of TPU it’s more flexible.
Now posted: Case for Librem 5? - #347 by kuleszdl
I use this https://www.thingiverse.com/thing:5146552
since more than one year. It’s big but,it work very well!
Because Librem 5 is a burning minipc (so a case rise furthermore temperature) I looked for and found on Amazon an universal bumper!
It’s not tailor made on it but it’s working
