Phone Contacts, and Messages app not working
I need to reinstall the applications and their deps, to see if this fixes the issue. How do I do so?
If there is a package x that you want to reinstall, then you can do
sudo apt reinstall x
Alternatively, you can explicitly remove it first and then install it again afterwards:
sudo apt remove x
sudo apt purge x
sudo apt install x
(I’m not sure if that would have precisely the same effect as the “apt reinstall”, or if there may be some difference)
I may just have to reflash
Okay, after externally backing up anything important, let me know if you want instructions for reflashing Byzantium or Crimson.
I backed up most everything. I will reflash this evening
